Mozilla サポートの検索
サポート詐欺に注意してください。 私たちはあなたに通話やショートメッセージの送信、個人情報の共有を求めることはありません。疑わしい行為を見つけたら「迷惑行為を報告」からご報告ください。
詳しく学ぶ
このスレッドはアーカイブに保管されました。 必要であれば新たに質問してください。
Can't recieve messages. get error 5.7.0 authentication required???email right, now what???
  • 3 件の返信
  • 1 人がこの問題に困っています
  • 3 回表示
  • 最後の返信者: Matt
An update came thru and since then I've not been able to send messages. Get error message... "An error occurred while sending mail. The mail server responded: 5.7.0 Authentication required. Please verify that your email address is correct in your account settings and try again." My e-mail address is correct...now what?
すべての返信 (3)
In order for us to better investigate this issue you need to add a little more non-personal information.
Please add the troubleshooting information to your post To find the Troubleshooting information:
  • Open Help (or click on three-line-icon and select Help)
  • Choose Troubleshooting Information
  • Use the button Copy to clipboard to select all. Do not check box "Include account names"!
  • Paste this in your post.
Application Basics
   Version: 38.3.0
   User Agent: Mozilla/5.0 (Windows NT 6.1; WOW64; rv:38.0) Gecko/20100101 Thunderbird/38.3.0
   Profile Folder: Show Folder
             (Local drive)
   Application Build ID: 20150928051427
   Enabled Plugins: about:plugins
   Build Configuration: about:buildconfig
   Memory Use: about:memory
 Mail and News Accounts
   account1:
     INCOMING: account1, , (none) Local Folders, plain, passwordCleartext
   account2:
     INCOMING: account2, , (imap) imap.xxx.edu:143, alwaysSTARTTLS, passwordCleartext
     OUTGOING: smtp.xxx.edu:587, plain, passwordCleartext, true
 Crash Reports
 Extensions
   Lightning, 4.0.3.1, false, {e2fda1a4-762b-4020-b5ad-a41df1933103}
 Important Modified Preferences
     accessibility.typeaheadfind.flashBar: 0
     browser.cache.disk.capacity: 358400
     browser.cache.disk.smart_size_cached_value: 358400
     browser.cache.disk.smart_size.first_run: false
     browser.cache.disk.smart_size.use_old_max: false
     extensions.lastAppVersion: 38.3.0
     font.name.monospace.el: Consolas
     font.name.monospace.tr: Consolas
     font.name.monospace.x-baltic: Consolas
     font.name.monospace.x-central-euro: Consolas
     font.name.monospace.x-cyrillic: Consolas
     font.name.monospace.x-unicode: Consolas
     font.name.monospace.x-western: Consolas
     font.name.sans-serif.el: Calibri
     font.name.sans-serif.tr: Calibri
     font.name.sans-serif.x-baltic: Calibri
     font.name.sans-serif.x-central-euro: Calibri
     font.name.sans-serif.x-cyrillic: Calibri
     font.name.sans-serif.x-unicode: Calibri
     font.name.sans-serif.x-western: Calibri
     font.name.serif.el: Cambria
     font.name.serif.tr: Cambria
     font.name.serif.x-baltic: Cambria
     font.name.serif.x-central-euro: Cambria
     font.name.serif.x-cyrillic: Cambria
     font.name.serif.x-unicode: Cambria
     font.name.serif.x-western: Cambria
     font.size.fixed.el: 14
     font.size.fixed.tr: 14
     font.size.fixed.x-baltic: 14
     font.size.fixed.x-central-euro: 14
     font.size.fixed.x-cyrillic: 14
     font.size.fixed.x-unicode: 14
     font.size.fixed.x-western: 14
     font.size.variable.el: 17
     font.size.variable.tr: 17
     font.size.variable.x-baltic: 17
     font.size.variable.x-central-euro: 17
     font.size.variable.x-cyrillic: 17
     font.size.variable.x-unicode: 17
     font.size.variable.x-western: 17
     mail.openMessageBehavior.version: 1
     mail.winsearch.enable: true
     mail.winsearch.firstRunDone: true
     mail.winsearch.global_reindex_time: 1443199229
     mailnews.database.global.datastore.id: fda9c72c-f341-47bb-9369-f64d4ddc2b9
     network.cookie.prefsMigrated: true
     network.predictor.cleaned-up: true
     places.database.lastMaintenance: 1444059321
     places.history.expiration.transient_current_max_pages: 104451
     plugin.importedState: true
 Graphics
     Adapter Description: Intel(R) HD Graphics 5500
     Vendor ID: 0x8086
     Device ID: 0x1616
     Adapter RAM: Unknown
     Adapter Drivers: igdumdim64 igd10iumd64 igd10iumd64 igdumdim32 igd10iumd32 igd10iumd32
     Driver Version: 10.18.14.4170
     Driver Date: 3-16-2015
     Direct2D Enabled: false
     DirectWrite Enabled: false (6.2.9200.17461)
     ClearType Parameters: ClearType parameters not found
     WebGL Renderer: false
     GPU Accelerated Windows: 0
     AzureCanvasBackend: skia
     AzureSkiaAccelerated: 0
     AzureFallbackCanvasBackend: cairo
     AzureContentBackend: cairo
 JavaScript
 Incremental GC: 1
 Accessibility
   Activated: 0
   Prevent Accessibility: 0
 Library Versions
     Expected minimum version
     Version in use
     NSPR
     4.10.8
     4.10.8
     NSS
     3.19.2 Basic ECC
     3.19.2 Basic ECC
     NSS Util
     3.19.2
     3.19.2
     NSS SSL
     3.19.2 Basic ECC
     3.19.2 Basic ECC
     NSS S/MIME
     3.19.2 Basic ECC
     3.19.2 Basic ECC
Well that was pointless. I asked you for troubleshooting information so I could check your settings. You chose to remove the server names so there is nothing to check.
